Re: A most curious problem
Silverfox Sullivan /
It does not sound like a soft sieze to me as it idles fine.
It sounds like you are not getting enough fuel flow to the float bowl to keep up with your high speed running.
Have you checked your fuel filters and the filter screen on the fuel tap up inside the fuel tank?
And adjusting the fuel mixture screw only effects idle. Does not do anything at fuel throttle.
