Moby oby oby
K, So i got my moby traveler running, but its stuck on full blast, the throttle seems to be useless, I'm assuming its something in the carb, but i know nothing about carbs....
Re: Moby oby oby
stuck throttle cable.
Motobecane carbs are retardedly simple...lol
just take it off and give it a good cleaning.
also good idea if the bike has been outside for a long time then replace the throttle cable.
When i put carbs backtogether i usually put a little 2 stroke oil on the slide and make shuire its nice and clean. Prevents that randomn sticking!
but some motobecanes i have have sitcky handles so i have cruise controll!!!!
Re: Moby oby oby
Mike Scouty McScoutington /
nothing like the cruise control.
Re: Moby oby oby
steveintoronto /
i thought that was only available on hondas!
Re: Moby oby oby
Well, the cruise control.....would be great if it would GRADUALLY come on, but when it starts....its on full...WHEE!
Re: Moby oby oby
someone did not line up the throttle when the put the carb back together.
that is my guess
if you are lucky you did not break the tab
Re: Moby oby oby
cruise control kicks ass. to turn it off you gotta wd-40 the cable. maybe the slide in the carb was put in wrong
Re: Moby oby oby
tomos has it too! :D
Re: Moby oby oby
yea, the tomos i had a while back had it too.
nice feature. Just make shure you have a functioning kill switch and brakes!!!
Re: Moby oby oby
yeah, my moby has cruise control too :-)
it does turn with ease, (not always full on) but if i pull the throttle all the way back it sticks there and just stays, kinda funny. is it bad? is that just needing a little lube on the slide? not that i mind the CC.
