I don't know what the decompression valve does on my Bravo would someone give me a quick and dirty run down of it's use and adjustment. Thanks...Steve
Used to stop or start the engine. Releases compression in the cylinder. If you hold it open, the engine will die(no compression). When starting, holding it open releases compression and makes it easier to for the cylinder to function. The engine wont start until you let go of it and restore compression. that help?
ahhh I see. Yup hey thanks for the info. Steve
