Re: Suzuki Fa50 unknow fuel line
RustyBikes /
Ben,
I looked at the pic.
The rubber hose you have pulled up should point down.
If it wont run with it pointing down then the drain screw is probabily loose and the bowl is not filling with fuel.
The screw faces the other side of the engine (Left as you sit on it) it's near the bottom of the fuel bowl.
I dont think you can reach it with the carb installed.
Have you had the carb off and been fiddleing with it or is this a new ped you are trying to get running.
Rusty
Ps. what position is your fuel valve pointing?
Also there should be a hose running from the brass nipple #5 to the vac. port of the fuel valve.
This cuts off the flow of fuel when the bike is not running.
RB
  Suzuki Fa50 unknow fuel lineTopic by: Ben Ben 03/23/06 07:22AM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/23/06 03:13PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/23/06 03:17PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/23/06 03:33PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mike Rivera Mike Rivera 10/04/19 05:10PM
  Re: Suzuki Fa50 unknow fuel lineRe: P D P D 10/04/19 07:07PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mike Rivera Mike Rivera 10/07/19 05:27PM
  Re: Suzuki Fa50 unknow fuel lineRe: William William 03/23/06 09:21PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/23/06 09:30PM
  Re: Suzuki Fa50 unknow fuel lineRe: Rolland Rolland 03/23/06 10:49PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/24/06 10:16AM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/24/06 01:17PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/24/06 01:35PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/24/06 02:12PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/24/06 02:34PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/24/06 03:06PM
  Re: Suzuki Fa50 unknow fuel lineRe: Ben Ben 03/24/06 03:02PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/24/06 03:25PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/25/06 10:57AM
  Re: Suzuki Fa50 unknow fuel lineRe: Ben Ben 03/25/06 02:41PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/25/06 04:16PM
  Re: Suzuki Fa50 unknow fuel lineRe: Ben Ben 03/25/06 04:49PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/25/06 04:48PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/25/06 09:45PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/25/06 10:05PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/26/06 09:43AM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/26/06 02:05PM
