Re: Suzuki Fa50 unknow fuel line
RustyBikes /
Good point.
I have here in my hand a Carb for the FA50.
It has a nipple at the bottom of the bowl with a nearby screw for draining the carb in prep for storage I assume.
This nipple is also connected to a vertical brass tube which is in the bowl and serves as a over flow vent.
The jet seat for the needle is close to the same height, off by about 2mm.
So all it should take is to lean out the needle by moving the clip up 2 or 3 notches.
I will give it a try and see what happens.
I have a carb/manifold that has been enlarge with a Dremmel grinder, (not by me) it leans out real bad at just over 20mph due the the small jet, I pull on the choke and get a burst of power.
The carb is clean.
I have a Chinese jet that was drilled with a #50 drill (if I remember correctly,) anyhow it's bigger than the stock jet and I will let you know what happens.
Rusty
  Suzuki Fa50 unknow fuel lineTopic by: Ben Ben 03/23/06 07:22AM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/23/06 03:13PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/23/06 03:17PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/23/06 03:33PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mike Rivera Mike Rivera 10/04/19 05:10PM
  Re: Suzuki Fa50 unknow fuel lineRe: P D P D 10/04/19 07:07PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mike Rivera Mike Rivera 10/07/19 05:27PM
  Re: Suzuki Fa50 unknow fuel lineRe: William William 03/23/06 09:21PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/23/06 09:30PM
  Re: Suzuki Fa50 unknow fuel lineRe: Rolland Rolland 03/23/06 10:49PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/24/06 10:16AM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/24/06 01:17PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/24/06 01:35PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/24/06 02:12PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/24/06 02:34PM
  Re: Suzuki Fa50 unknow fuel lineRe: joew joew 03/24/06 03:06PM
  Re: Suzuki Fa50 unknow fuel lineRe: Ben Ben 03/24/06 03:02PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/24/06 03:25PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/25/06 10:57AM
  Re: Suzuki Fa50 unknow fuel lineRe: Ben Ben 03/25/06 02:41PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/25/06 04:16PM
  Re: Suzuki Fa50 unknow fuel lineRe: Ben Ben 03/25/06 04:49PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/25/06 04:48PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/25/06 09:45PM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/25/06 10:05PM
  Re: Suzuki Fa50 unknow fuel lineRe: RustyBikes RustyBikes 03/26/06 09:43AM
  Re: Suzuki Fa50 unknow fuel lineRe: Mitch Mitch 03/26/06 02:05PM
