Puch wiring help
Blaise Margherito /
I have my puch totally fixed up until this point. My light/horn switch needs to be wired and for some reason i cant get it working right. I extended the wires so they would fit but I cant get the horn to work right when hooked up. Here is a picture of the switch I am using. If you have it which wires go into which holes?
Thanks
Re: Puch wiring help
Blaise Margherito /
here are pics of the inside of the switch w/ the wire extentions.
Leon Swarmer /
I don't know what colors are suppose to go where. But I can tell you a problem that you have or will have. You've stripped way too much wire to get those connected... That much bare wire bouncing around will ground it out.
I don't know your experince level and you may have already been planning on using a bunch of electricians tape on this. hope I haven't insulted you.
Leon
50plus is right. you overdid the stripping big time.
Blaise Margherito /
No I know i overstripped it. I used a utility knife cause i couldnt find where i put my wire stripper. Its all been fixed now.
Thanks
hey blaise margherito you have a sweet name.
My newports just like yours
