Re: HELP! MY MOPED IS SICK!
Rich Battag /
Mostly likely,, broken rings, remove fly wheel cover 1st. then Remove 4 nuts on head.Remove 2 exhaust nuts and pull down header clear of cylinder. Try to rotate flywheel forward and backwards if cylinder moves with motion, it's seized or broken rings, most of the time with broken rings. you'll see dents/chucks on the dome of the head As soon as you pull the head. if cylinder slides off piston easy. and flywheel still won't move. you have other issues.
Tools you'll need to check.
A Ratchet driver, 10mm socket and short extension.( For nut removal)
a flathead screwdriver. (for fly wheel cover)
Good luck
POWEREDBYPUCH
  HELP! MY MOPED IS SICK!Topic by: Heidi1984 Heidi1984 03/16/06 03:29PM
  Re: HELP! MY MOPED IS SICK!Re: ed james ed james 03/16/06 03:58PM
  Re: HELP! MY MOPED IS SICK!Re: Heidi1984 Heidi1984 03/16/06 07:25PM
  Re: HELP! MY MOPED IS SICK!Re: Leon Swarmer Leon Swarmer 03/16/06 07:27PM
  Re: HELP! MY MOPED IS SICK!Re: Heidi1984 Heidi1984 03/16/06 07:36PM
  Re: HELP! MY MOPED IS SICK!Re: Ben Van Zoest Ben Van Zoest 03/17/06 05:28AM
  Re: HELP! MY MOPED IS SICK!Re: Brett Walker Brett Walker 03/16/06 07:53PM
  Re: HELP! MY MOPED IS SICK!Re: ed james ed james 03/17/06 07:42AM
  Re: HELP! MY MOPED IS SICK!Re: Rich Battag Rich Battag 03/17/06 11:23AM
  Re: HELP! MY MOPED IS SICK!Re: thor thor 03/17/06 03:18PM
  Re: HELP! MY MOPED IS SICK!Re: ~ DeeZy ~ DeeZy 03/17/06 07:37PM
  Re: HELP! MY MOPED IS SICK!Re: ed james ed james 03/17/06 07:59PM
  Re: HELP! MY MOPED IS SICK!Re: Heidi1984 Heidi1984 03/17/06 09:55PM
  Re: HELP! MY MOPED IS SICK!Re: Leon Swarmer Leon Swarmer 03/17/06 10:42PM
  HELP! MY MOPED IS SICK!Re: Heidi1984 Heidi1984 03/17/06 09:49PM
  Re: HELP! MY MOPED IS SICK!Re: ed james ed james 03/17/06 09:56PM
  Re: HELP! MY MOPED IS SICK!Re: Fingers Fingers 03/17/06 10:42PM
  Re: HELP! MY MOPED IS SICK!Re: Heidi1984 Heidi1984 03/22/06 02:08AM
  Re: HELP! MY MOPED IS SICK!Re: Fingers Fingers 03/22/06 01:41PM
  Re: HELP! MY MOPED IS SICK!Re: Rich Battag Rich Battag 03/22/06 09:18PM
  Re: HELP! MY MOPED IS SICK!Re: Ben Van Zoest Ben Van Zoest 03/18/06 02:55AM
  Re: HELP! MY MOPED IS SICK!Re: Heidi1984 Heidi1984 03/18/06 04:49PM
  Re: HELP! MY MOPED IS SICK!Re: ~ DeeZy ~ DeeZy 03/18/06 06:22PM
  Re: HELP! MY MOPED IS SICK!Re: ed james ed james 03/18/06 07:48PM
