Lower edges of gas tank are rusted through... What is the BEST way to repair this? Any suggestions on a fix would help.
Lead patching is the best way... not the easiest. The easiest would be welding in patch pieces.. but you'd have to do it just right, otherwise you're going to have a very poor looking job.
DannyMoped07
real bummer man!
If it's not too bad, I've had success using JB Weld.
i usally just poop in teh gas tank it works really good
Pooping really does work wonders for your moped it did for mine
Yaknow what? That's to be expected from someone with no profile. New Jersey?
DannyMoped07
The easiest and probably the cheapest is to replace the tank - if it's
a top-tank. If it's an in-frame tank - you can always use Kreem or
POR-15 tank lining kits. The POR is better, but either will work.
For a moped I personally would empty the tank, wash it out with
alcohol, put a heat lamp on it to make sure it's dry, then clean and
scuff the outside before applying J/B Weld to patch it.
Another great epoxy that will work even better is Gluvit. Travco up
in Mass. makes it and marine supply stores carry it. Clean the
bottom of the gas tank as though you were going to paint it. Then
mix up and paint on two coats of Gluvit. Then, after it sets overnight,
sand and paint it. It will never leak again.
PHM
lol idk man thats tuff i thought my tank was bad. if your ne good at welding try that. I have no excperience in repairing a gas tank that bad.
EZ,
Do you have a picture of the tank? It may be easier to determine the best method of repair if we actually see the damage.
DannyMoped07
I just JB welded a pin hole in my tank, so jb weld works well, I held a spark plug in a cylinder head of a tractor with jb weld for 5 years of every day use :P
maybe i ought to try that stuff.
JB Weld works, there's also gas tank repair kits you can buy in auto parts stores. I usually braze my gas tanks. A plumbers acetylene torch has enough heat and you can buy the brass rod at Home Depot. Just make sure the tank is empty, and then you even fill it with water, otherwise go boom!
Thank Yiou to those of you who responded - with the exception of 'bigjoe poophead'... What a waste!
I ground er' down and used liquid steel letting it ozz inside as much as possible. Did two different coats, and it really looks like it will work out great. Again - Thanks! EZ
