What kind and size fuel line for a dellorto
Hey doods. I need some new fuel line for my dellorto carb. Can someone please tell me what kind and size that u guys most often use for ur peds? Thanks a lot!
-Aaron
Re: What kind and size fuel line for a dellorto
3/16
John Joedicke /
and put a filter on the line
just about every auto parts and hardware store has clear hose of several different widths, and thats what i get. you can see the fuel go thru them.
Walter Kravitz /
3/16 should be a good snug fit. Make sure to put a fuel filter in there too, never hurts.
roadent$ craig /
where does the fuel filter attach to?
Hey Zack,
Will the filter restrict the fuel at all?
Thanks for the tip.
-Aaron
no it wont
you cut the fuel line in 1/2 so you have one end connected to the carb and the other connected to the gas tank turn the petcock off, than take the two free ends you have in the middle and connect the lines to the inlet and outlet of the filter
be sure to not put the filter on backwords or it will clog faster. Usually there is a transparent arrow on the filter if you look hard enough.
