You may want to Recheck wires, when you changed to points and condenser a wire may be pinched in back of the stator plate.
I remove all stock wires on most of the peds I rebuild, But, it is nice to have stock wires and switches too.
Here's a way to Check if your getting a short in your wiring Harness.
Solid blue----------------------------------Coil Hot
Solid green and Green Black-------------Brake lights
Blue Black--------------------------------Ground for switches
Yellow-------------------------------------Headlight
Grey---------------------------------------Taillight
Brown-------------------------------------Ground
At "Wire Harness Block" remove the following "Lead in" wires(Coming out of motor, or "bottom side of Harness")
Solid blue,,blueblack and Both greens
(you'll need 2 extra wires)
1 will need the same sleave fitting
as coil.
Attach that wire to the Solid Blue wire and attach to coil.
On blueblack wire attach the other spare wire and Ground that to the frame somewhere.
The 2 Greens join/twist them together.
Try to start.
if it starts,,,, then you have an issue somewhere in your wires or switches, Most likely grounding out.(switches/gates are the Following,, BRAKE LIGHTS,HORN,HEADLIGHT,On/OFF if there)
If it doesn't,,,,,,,It's not the Wires.
Ragstrecher
