gas tank clean
roadent$ craig /
alright, im going to get right to the point...how do i clean a gas tank?...im about to test to see if it is infact dirty...and if it is...then i will need to clean it
Re: gas tank clean
Jason Luther /
you start by using the search button
Re: gas tank clean
i would just use water. but just make a reasonable effort to dry it out when you're done.
Re: gas tank clean
See Ya Moped Army /
Water won't do jack to remove rust and varnish. Use the Search Function to find the various methods to clean out gas tanks.
Re: gas tank clean
for sure, rust can be a problem. i had a moped once that i had to constantly siphon the gas out of and blow out the filter, but eventually the problem went away.
Re: gas tank clean
i sure hope you were kidding about the water thing...
This is what you do -
If there is yak from dried up gasoline and two stroke oil, use
Yamaha Carb cleaner, mixed about three-to-one with gasoline,
to soak the tank for a day or two.
And/or if there is rust: dry the tank well and fill it with white
vinegar. Over night soaking will have all rust etched off.
Rinse it with gasoline. Let it dry.
Done.
PHM
