motobecane timing without tool?
can anyone help me set the timing on my engine without the timing tool. the timing cam came off when cleaning the points. am i screwed or is there another way to set the timing without using a timing tool
Re: motobecane timing without tool?
The timing tool is just a guide for measurement. I use a peice of a ruler and a hex key. The hex key show you where the piston is, and the chunk of ruler allows you to set the point opening at 2mm before top dead center.
I wrote an article with pictures on the subject.
https://www.mopedarmy.com/forums/discuss/1/173041/173041/
Couldn't you just cut the ruler so that it will fit in the cylinder, instead of using a chunk of ruler on top of the cylinder and a hex key in the cylinder? If you're chopping up the ruler anyway, might as well.
I actually use a chunk of broken measuring tape that I found on the ground. All this cutting and modifying smacks of effort.
