Re: Sachs Wiring
Cpt. F. /
If I remember correctly, starting from the switch, take the brown(black?), yellow, and white wires (3 of the 5, I believe), and cut them about 5 inches before they go into the harness. Take a wire cap nut, or similar electrical connector, and connect all 3 of these wires together. Then you will always a have a headlight and tailight. I think the other 2 wires can be removed. But double check where they go first. If there's a red(purple?) one it goes to the horn, and is all but useless. The last one may be the 'flasher' button, if it is, it's also useless.
Does that sound right?
  Sachs WiringTopic by: Craig Craig 02/22/06 09:43AM
  Re: Sachs WiringRe: Cpt. F. Cpt. F. 02/22/06 01:11PM
  Re: Sachs WiringRe: Cpt. F. Cpt. F. 02/22/06 01:14PM
