forks/suspension - what type of grease
while i have my bike completely taken apart, i want to make sure the suspension is well lubed. (The bike should run close to 50 mph once I have the mods done to it, so I want everything in top shape if I'm going to be cruising around at such high speeds). So I've taken apart the front fork completely, but I can't seem to get the chrome suspension tubes out of the fork piece. See the pic. Anyway, has anybody done this before? How do you clean and re-lube the front suspension? thanks.
Idid a search, you can do that by looking at top of this page for search, I found this copied and pasted it and I have done this recently:
Just flip it , the moped, upside down, get the forks pointing straight up, and spray a load of penetrating oil into the suspension.
then let it sit for a day or two.
taking forks off is very time consuming. All electric, and cables must be removed. And that is the easy part!
Re: forks/suspension - what type of grease
yeah and about that gas leak your going to have? killer. HOw about all the fluids in the motor, bad to be upside down?
lol, the pic in my post should make it pretty clear that I've managed to remove the fork completely. In fact, I have nearly everything removed from the frame except the kickstand. Anyway, anybody know how to do this properly?
