Puch ring alignment
It says in the manual to make sure you align the ring gap with the locating pins? What locating pins? I'm trying to put the cylinder back on....
Re: Puch ring alignment
Smitty Smith /
...in the grooves of the piston, where the rings go around the piston. Look all the way around and you should find them. Both will be on the same side, and pay attention to their orientation in the groove, and the shape of the rings ends...
If you look all round the piston grooves you will see the ends of some small pins that are in the piston. The ring gaps are to be position there for each ring when you put the piston in the cylinder
Found 'em. Thanks!
