Re: 1981 Tomos Silver Bullet won't restart!
Sean /
there should be gear oil (tranny fluid) that has to be changed, there should be a drain plug on bottom and a fill screw on top if its anything like an a35 motor. (right side of case). I would then run it ofr about 50 miles and change it again so your sure all the bad gunk is out of there. As for the restarting... i'm not completely sure.
