Re: sealing case halves
MTech -> /
"permatex":http://www.permatex.com/motorcycle/PermMotoSeal.asp?automotive=yes&f_call=get_item&item_no=29132
Guaranteed to outperform the most popular brands. Gasoline resistant gasket maker is designed for use on motorcycles, watercraft, snowmobiles and karts. Resists high temperatures and performs well at low temperatures. Effective on uneven joint surfaces.
Suggested Applications:
Cylinder head top covers, center & end covers (transmissions), crank case halves, cam covers, transmission case halves, exhaust manifold seals, timing chain cases, cylinder case halves, side covers, clutch housings
important thing to look at is HOW resistant to gas/oil it is, not just IF it is resistant....and vibration too..The suggesstion of using it in the crankcase from the manufacturer is also somewhat reassuring.
available in some automotive shops, call before you visit!
