blinkers on all lights blink?????????
My right blinker works but when i turn my left blinker on all my lights blink. This is on a 2000 ttlx and i'v tryed everything.What do you think is wrong woth it?
Re: blinkers on all lights blink?????????
mabey you hooked a wire up wrong......
no already checked and if i hooked it up wrong the right one would do the same thing.
check for a wire shorting out on the frame. Under the tank, the screw that holds the wire cover is a common one. also check under the rear fender.
I dont think it could be wire shorting out because it still like it on the relayer because the lights blinks like the normal blinker would.
My Revival did that every once in a while. I thought it was cool. All I had to do was flip the switch off then back on and it would be normal. My solution: Take them off.
all the blinker i want them on still cause there mini carbon ones and they look sweet.
My solution would be to double check wiring again, you can never check too many times.
John Joedicke /
Sounds like a ground issue.
ya could be did you ground your blinkers dillon?
nope didn't ground my blinker but the left blinkers ground is invisable.
