engine wont start and sometimes makes loud BANG!!
so, i know the problem is the timing, would it be too soon, or too late?
too late i guess, befause the BANGS comes from the exhaust
am i right?
thanks
g.b.
Re: engine wont start and sometimes makes loud BAN
normally exhaust if retarded timing.. try to advance.. also check the magneto and make sure it is tight. I have seen one that has a loose nut drive the timing crazy.. You can take out the spark plug put the back end of a pencil in the hole and slowly rotate the motor to find TDC. then look at the points to see of you are close
