Re: piston won't slide into cylinder...??
Jim Madden /
i just read the peugeot repair manual and they say to remove the head nuts in a criss cross fashion to avoid warping! i don't know weather they ment the head or cylinder? and not to touch the skirts as they are extremly fragile, and the piston only goes in from the bottom.Check out page 27.
like i said barring any damage/wrong parts I would assume it's a temp. difference i'ld get an a/c unit and cool the motor piston and slightly heat the cylinder with a hair dyer or something don't do anything destructive like honing.Jim
  piston won't slide into cylinder...??Topic by: Brennan O. Brennan O. 01/31/06 08:18PM
  Re: piston won't slide into cylinder...??Re: joe ho joe ho 01/31/06 08:28PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 01/31/06 08:37PM
  Re: piston won't slide into cylinder...??Re: ryan ryan 02/01/06 09:06PM
  Re: piston won't slide into cylinder...??Re: bc mtl bc mtl 01/31/06 08:42PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 01/31/06 08:45PM
  Re: piston won't slide into cylinder...??Re: Leon Swarmer Leon Swarmer 01/31/06 08:50PM
  Re: piston won't slide into cylinder...??Re: Jason Luther Jason Luther 01/31/06 08:54PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 01/31/06 08:58PM
  Re: piston won't slide into cylinder...??Re: joe ho joe ho 01/31/06 09:07PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 01/31/06 09:12PM
  Re: piston won't slide into cylinder...??Re: Jason Luther Jason Luther 01/31/06 09:13PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 01/31/06 09:26PM
  Re: piston won't slide into cylinder...??Re: Bort Hoff Bort Hoff 01/31/06 09:23PM
  Re: piston won't slide into cylinder...??Re: Mike Bartell Mike Bartell 01/31/06 11:15PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 01/31/06 11:30PM
  Re: piston won't slide into cylinder...??Re: Jason Luther Jason Luther 01/31/06 11:56PM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 02/01/06 12:42AM
  Re: piston won't slide into cylinder...??Re: Bort Hoff Bort Hoff 02/01/06 01:34AM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 02/01/06 02:34AM
  Re: piston won't slide into cylinder...??Re: R . R . 02/01/06 04:23AM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 02/01/06 04:36AM
  Re: piston won't slide into cylinder...??Re: Jim Madden Jim Madden 02/01/06 06:44AM
  Re: piston won't slide into cylinder...??Re: Rick Rick 02/01/06 07:18AM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 02/01/06 07:26AM
  Re: piston won't slide into cylinder...??Re: Jim Madden Jim Madden 02/01/06 11:24PM
  Re: piston won't slide into cylinder...??Re: Jim Madden Jim Madden 02/02/06 12:18AM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 02/02/06 01:57AM
  Re: piston won't slide into cylinder...??Re: Jason Luther Jason Luther 02/03/06 01:30AM
  Re: piston won't slide into cylinder...??Re: joeho joeho 02/01/06 11:26AM
  Re: piston won't slide into cylinder...??Re: Brennan O. Brennan O. 02/01/06 06:32PM
  Re: piston won't slide into cylinder...??Re: Silverfox Sullivan Silverfox Sullivan 02/03/06 12:24PM
  Re: piston won't slide into cylinder...??Re: Bort Hoff Bort Hoff 02/01/06 06:59PM
  Re: piston won't slide into cylinder...??Re: Rick Rick 02/01/06 09:30PM
  No longer an issue...Re: Brennan O. Brennan O. 02/04/06 10:47PM
  Re: No longer an issue...Re: joe ho joe ho 02/04/06 11:25PM
  Re: No longer an issue...Re: Brennan O. Brennan O. 02/04/06 11:47PM
  Re: No longer an issue...Re: Rick Rick 02/04/06 11:32PM
  Re: No longer an issue...Re: Brendan Brendan 02/05/06 12:32AM
  Re: No longer an issue...Re: John Joedicke John Joedicke 02/05/06 01:34AM
  Re: No longer an issue...Re: Sean Sean 02/05/06 04:37AM
  Re: No longer an issue...Re: Jim Madden Jim Madden 02/05/06 06:37AM
  Re: No longer an issue...Re: joe ho joe ho 02/05/06 09:00PM
  Re: No longer an issue...Re: Kenny J Kenny J 02/07/06 02:12PM
