removing a crank arm
alright, I posted on here a while back about removing a crank arm and made a fool of myself. Now, I have tried removing the screw with both the tap of a hammer and the clamp and socket trick someone told me about. Both with no luck. Any more sugestions? Thanks.
Re: removing a crank arm
its really easy,
heat the end of the crank arm that has the peg in it with a torch unitl it gets nice and hot. then just tap out the peg
Jason Luther /
dont get it too hot though, or else you might fry the seal
did you support the arm and shaft with anything?
hold pedal in your hand, make sure everything is lined up at a 90
Use the hammer to pound the pin in farther before trying to pound it out. Driving the pin in farther, just a hairs breth, will break down or the bonds of rust or whatever that has the pin stuck in place.
The opperative word here is pound, not tapp.
Thanks all. I guess I'll have to get a little more agressive with and try adding some heat.
