Motobecane Magneto help
Ironhead_Rat /
I need help with the internal wiring of a post 78 motobecane magneto and determining whether the parts are still functioning. Do the wires coming from the exciter coil and the condenser both just connect along with the grey wire to the coil at the points terminal? If so, should there be any resistance to ground when the points are open? Is there a simple way to test whether or not the coil/condenser has shorted out? (if anyone has an internal wiring diagram for the magneto, that would be immensly helpful)
