Re: Sachs clutch question
leefran /
After setting stored in basement for 20 years, my 1980 Sachs Commuters clutch didn't work smoothly, the basement had flooded a couple times, getting to 24 inches of water in it and apparently into the clutch area, I drained out old and put in fresh fluid , worked a little better, after about 10 miles I drained the fluid and put in fresh again, worked better and finally about 15 miles later it works as smooth as silk.
It don't take much water/condensation to cause problems in clutch.
