Sachs clutch question
I have two sachs 505/1 engines...one has much better acceleration than the other. It feels like the slower accelerating ped has a clutch that is not engaging all the way, feeling almost like a two speed. I know it is not a two speed and am wondering what I need to do to remedy this problem to increase acceleration. Thanks.
Re: Sachs clutch question
new fiber plates in the clutch and rough up the metal ones a little.
You also may just be low on fluid- check by unscrewing the plastic plug on the side.
After setting stored in basement for 20 years, my 1980 Sachs Commuters clutch didn't work smoothly, the basement had flooded a couple times, getting to 24 inches of water in it and apparently into the clutch area, I drained out old and put in fresh fluid , worked a little better, after about 10 miles I drained the fluid and put in fresh again, worked better and finally about 15 miles later it works as smooth as silk.
It don't take much water/condensation to cause problems in clutch.
Thanks, my fluid is perfect, I guess I'll have to try the clutch plates.
