hi everyone,
Would mobil 1 ATF work in a tomos transmission, it says dexron III or should i get the type F ATF from mobil, or does someone recommend a company or fluid type that i should use. THANX
hi everyone,
i run 75/80w Gear Oil made by Bel-Ray
thanks, but what is the best way to flush the tranny with out re-building it.
Also, those bolts on the top and bottom are for filling and draining it right? (Those bolts means the silver ones by them selves on the top and bottom)
