Loose peice
Recently my Peugeot 103 LVS started making a weird cranking sound while it was running, I opened it up, and that big plastic thing at the end of the engine (the air intake silencer?) had come completely loose. It's been damaged and won't reattach. Is it fine to run without it? If not, how can I fix it?
Thanks!
Sam
Re: Loose peice
steveintoronto /
is that an air-box that you're referring to? it's either that or the rubber boot that provides a seal between the air filter and the air intake on the carb. either way, if it's a point where your bike is drawing air into the engine you should probably try to get it fixed to keep debris out of your fuel system.
Re: Loose peice
steveintoronto /
can you post a pic of the busted piece?
