Re: Loose peice
steveintoronto /
is that an air-box that you're referring to? it's either that or the rubber boot that provides a seal between the air filter and the air intake on the carb. either way, if it's a point where your bike is drawing air into the engine you should probably try to get it fixed to keep debris out of your fuel system.
