puch horn disease
Patrick Stover /
hello,
i just got the carb cleaned on my jc penny puch moped. ped started right up but it has that thing where the horn is always on a little bit. is it the horn? wirirng? horn/lights switch?
i have seen this on a few other maxis but i couldent remember how it was fixed.
anyone that knows how to fix this, feel free to post.
thanks, pat
Re: puch horn disease
Patrick Mattison /
tap it a couple times?
Patrick Stover /
pat OP
no, the horn shouldent be getting power at all. could this possbly have something to do with my running light/headlight being burnt out?
Easy way to fix the annoying horn problem is just to take the damn horn out. At the terminal block, find the blue/black wire and either put it in the same hole as the green/black wire of ground it.
No more horn, no more problem
horns are for pussies.
See Ya Moped Army /
The problem is most likely in the switch.
It'ts the switch... they get sticky when they get old... sparay some cleaner in it and work it a bit and it should free up :P
Patrick Stover /
pat OP
yeah, i think i will just do a horn removal. i honestly cant remeber a time when mopeding that i needed to give a slight buzz to someone.
It's illegal to run without one, not that I care, mine works about half the time. I also ride high every time. Nope, still haven't had any close calls with any drive-thrus and children in the way.
I like a horn when riding with someone else, so I can honk if I pull over, or have to get one's attention for some reason. When I come up on a car-load of females and they have a bumper sticker that says, "Honk if you're Horny" I'd be sad if my horn was sitting in some parts bin.
_DeeZy_
John Joedicke /
Switch is the problem, but if you are removing it put an old school bulb horn on to be legal.
