Not sure what the problem is
My 78 Garelli gulp matic 2speed it seems, is starting to have some problem. When the speedo hits 25mph it sounds like it's winding out. There's a higher pitch rattle, that sounds like it's turning to fast for it to keep up with itself. Now, less than usual will it catch and accelerate smoothly up to 30-32mph. Could this be as simple as tightening my chain? there's a little lag, other than that, I'm stumped. Any suggestions?
Re: Not sure what the problem is
Try looking at your clutch for starters. Kinda sounds like it's slipping.
The clutch eh?
how could it be the clutch? it shifts just fine. The problem is that it winds out around 25-27.
It'll shift just fine even if it slips.
ya it does sound like the clucth
Ben Van Zoest /
High end lag the top hole in the fuel riser tube maybe clogged
My 1 speed will slip AT THE DRIVE GEAR. Garellis use a smooth metal friction based lock for the gears. If the wrong amount of torque is on the gear, your second speed gear might be slipping on the shaft. Look up the removal and installation directions on mopedriders.org for torque requirements. BTW, the NOI and VIP engines use the same clutch....
Is the clutch something that has to be replaced, or can it be fixed?
replaced, if it's worn out. It _could_ be out of adjustment, but prob'ly not. sorry
