Re: update1, muffler Q?
joe ho /
well have you tried testing the cable. maybe its just thecable. carbon buildup is normal. put your pip in a fire or run a torch through it and heat it up. then tap it all over let it fall out. im sure you can use carb cleaner and stuff. check if your port is clogged too. have you tested your spark. the old sparkplug boots to eventually go. my ped was like that. i bought a new spark plug boot and voila problem solved. just becuase you see a spark doesnt mean its strong enough to ignite
  I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Topic by: Sara Sara 01/09/06 11:22PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: See Ya Moped Army See Ya Moped Army 01/09/06 11:49PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/10/06 12:38AM
  update1, muffler Q?Re: Sara Sara 01/10/06 11:41PM
  Re: update1, muffler Q?Re: Legendre Legendre 01/11/06 11:52AM
  Re: update1, muffler Q?Re: Sara Sara 01/11/06 09:00PM
  Re: update1, muffler Q?Re: joe ho joe ho 01/11/06 09:59PM
  Re: update1, muffler Q?Re: Sara Sara 01/12/06 12:20AM
  update 2 I've got my LEDS!Re: Sara Sara 01/12/06 12:25AM
  Re: update 2 I've got my LEDS!Re: jamesdelaney jamesdelaney 01/12/06 07:48AM
  Re: update 2 I've got my LEDS!Re: Sara Sara 01/14/06 10:50AM
  Re: update 2 I've got my LEDS!Re: jamesdelaney jamesdelaney 01/17/06 08:41AM
  Re: update 2 I've got my LEDS!Re: Nate Rogers Nate Rogers 01/12/06 05:49PM
  Re: update 2 I've got my LEDS!Re: Sara Sara 01/14/06 10:57AM
  Update 3 No spark!!!Re: Sara Sara 01/14/06 01:20PM
  Re: Update 3 No spark!!!Re: Jason Luther Jason Luther 01/14/06 03:33PM
  Re: Update 3 No spark!!!Re: ~ DeeZy ~ DeeZy 01/14/06 03:37PM
  Re: Update 3 No spark!!!Re: Sara Sara 01/14/06 03:49PM
  Re: Update 3 No spark!!!Re: Sara Sara 01/14/06 04:32PM
  Re: Update 3 No spark!!!Re: ilivefaster ilivefaster 01/15/06 02:24AM
  Re: Update 3 No spark!!!Re: sara sara 01/15/06 11:48AM
  Re: Update 3 No spark!!!Re: ilivefaster ilivefaster 01/15/06 05:02PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: ~ DeeZy ~ DeeZy 01/14/06 03:39PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Ben Van Zoest Ben Van Zoest 01/14/06 11:45PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/15/06 11:44PM
  Re: Update 3 No spark!!!Re: joe ho joe ho 01/15/06 07:40PM
  Re: Update 3 No spark!!!Re: Sara Sara 01/15/06 11:46PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/15/06 11:50PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/15/06 11:51PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/15/06 11:54PM
  NOOOO!!!!!!Re: Sara Sara 01/16/06 07:04PM
  Re: NOOOO!!!!!!Re: ~ DeeZy ~ DeeZy 01/16/06 07:20PM
  Re: NOOOO!!!!!!Re: Sara Sara 01/16/06 07:27PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: ~ DeeZy ~ DeeZy 01/16/06 07:21PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/16/06 07:28PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: ~ DeeZy ~ DeeZy 01/16/06 07:57PM
  Re: I NEED HELP IN MANY WAYS WITH MY PUCH MAXI!!!Re: Sara Sara 01/17/06 10:36AM
