Re: Carb Medic (by GUNK) does/should it work?
joe ho /
you dont need an air compressor. go to autozone or somewhere anc get carb cleaner in a spray can with a straw. go to http://www.mopedriders.org they might have carb diagrams there. carbs arent that confusing
just dont take the spring off the slide or you migth have a hard time putting it back take out the top where the cable comes in
and take out the lower body portion. turn off your petcock and pull the gas line off
then just take out the bowl. and spray thoroughtly in any crevace. then the tiny hole (the jet) needs to be cleaned. spray throug hthat. and clean the bown so nothing gets sucked into the jet. you should be done. ive only worked with bing carbs for puchs but you should be fine carbs arent too complex
