Re: muriatic acid a good idea?
Anthony K /
Luke, if you use the search function you can find several threads about this, but basically you're supposed to follow the muriatic acid wash with a phosphoric acid wash, it reacts with the newly exposed metal somehow and produces a more rust-resistant layer. Some people have used Coca-Cola (which contains phosphoric, citric, and carbonic acids) instead of the harder to find and more expensive phosphoric acid. If you use Coke, you need to make sure you've rinsed out the sugary residue... you can use denatured alcohol for this (it will also dissolve dried-up gas varnish).
I don't know if this is a good idea or not, but it might be cheaper and easier to use 91% isopropyl alcohol instead of denatured, you can get it at most drug stores. 72% is probably no good, it's 28% water and the leftover water can start re-rusting your tank, but in my experience the 91% evaporates pretty completely. Never tried it in a tank, though.
  muriatic acid a good idea?Topic by: luke luke 12/16/05 11:01PM
  Re: muriatic acid a good idea?Re: Daniel Van Donsel Daniel Van Donsel 12/16/05 11:05PM
  Re: muriatic acid a good idea?Re: See Ya Moped Army See Ya Moped Army 12/16/05 11:06PM
  Re: muriatic acid a good idea?Re: Anthony K Anthony K 12/17/05 12:58AM
  Re: muriatic acid a good idea?Re: ryan ryan 12/17/05 11:57AM
  Re: muriatic acid a good idea?Re: Xxxxx Xxxxx Xxxxx Xxxxx 12/17/05 02:31PM
  Re: muriatic acid a good idea?Re: Bill Borglund Bill Borglund 12/17/05 05:42PM
  Re: muriatic acid a good idea?Re: luke luke 12/18/05 08:42PM
  Re: muriatic acid a good idea?Re: Legendre Legendre 12/17/05 07:11PM
  Re: muriatic acid a good idea?Re: Harry Crank Harry Crank 12/20/05 03:36AM
  Re: muriatic acid a good idea?Re: Xxxxx Xxxxx Xxxxx Xxxxx 12/20/05 10:44PM
  Re: Epoxy useRe: timtune timtune 12/25/05 04:15PM
  Re: Epoxy useRe: Harry Crank Harry Crank 12/27/05 04:05AM
  Re: muriatic acid a good idea?Re: Brett Walker Brett Walker 12/21/05 10:01AM
  Re: muriatic acid a good idea?Re: Rick Rick 12/21/05 04:53PM
  Re: muriatic acid a good idea?Re: Xxxxx Xxxxx Xxxxx Xxxxx 12/21/05 07:04PM
  Re: muriatic acid a good idea?Re: Rick Rick 12/21/05 08:46PM
  Re: muriatic acid a good idea?Re: joe ho joe ho 12/21/05 11:22PM
  Re: Epoxy useRe: thor thor 03/06/06 01:21AM
  Re: Epoxy useRe: brystheguy brystheguy 03/06/06 01:31AM
  Re: Epoxy useRe: thor thor 03/06/06 03:49AM
  Re: Epoxy useRe: Jason Luther Jason Luther 03/06/06 09:11AM
  Phosphoric acid is better -Re: Poodle Head Mikey Poodle Head Mikey 03/07/06 10:47PM
