i have a 1978 Honda Express , i need a owners manual, and i need to know how to bypass ground wire for coil without useing a battery.
Not sure what you mean by that. I suppose you need to ground a particular wire, but you have no battery?
If thats the case, just stick said wire on the frame.
http://www.mopedriders.org/article_view.php?faq=2&fldAuto=52
Don't be too eager to run it without a battery. it uses the batt as a voltage regulator and if it's not there you will pop a $30.00 headlight
Leon
