Ok.....I'm confused about all my Motobecane Carbs....standard 50V's .......they look fine inside, nothing is clogged or gunked up at all, O rings are there and everything.....but when I run an engine with 1 of the 3 carbs that is doing this...it only passes enough feul quick enough for idling or very low throttle....if you give it too much throttle the engine dies due to lack of feul.....it's not the engine because the engine I tested with works fine with other Carbs.........
My guess is that is has to be the Foat or something.....has anyone figured out the prime setting of a float....
Any ideas will help
