Here is what you do:
fill it up all the way with gas, get a gas can that can hold a gallon or more, take the fuel line off your carb, stick it in the gas can, turn the petcock on to run, turn it to reserve, you should get a full flow on both settings, if it's slow then you have crud in there, after emptying the tank, take the petcock off, and clean it out, and you are done.
if for some reason with a full tank you get full flow out of the line, then it's in your carb, maybe an air vent is blocked? or a cloged filter?
but basicly, if you are not getting gas, start at one end, and work your way twards the other, untill you either find the problem, or knock something loose and fix it accedently, and if all else fails you have gas, all you are missing is a match.
