Re: Carb re-jetting
Sean /
re-jetting is putting a different jet screw in under the black bowl cap on your carb (tomos). Will allow either more or less fuel to enter into the motor at a time.
A plug chop is when you put in a new plug, then after a bit of running you take it out and check weather ur running lean, or rich or right perfect. if the plug is a golden brown its perfect.
