Carb re-jetting
What does it mean to re-jet a carburetor?
Re: Carb re-jetting
Also what the heck is a plug chop?
Re: Carb re-jetting
You would be suprised by all the info that can be found by searching.
Grey
Live to ride, Ride to work
Re: Carb re-jetting
search for moped dictionary
Re: Carb re-jetting
re-jetting is putting a different jet screw in under the black bowl cap on your carb (tomos). Will allow either more or less fuel to enter into the motor at a time.
A plug chop is when you put in a new plug, then after a bit of running you take it out and check weather ur running lean, or rich or right perfect. if the plug is a golden brown its perfect.
Re: Carb re-jetting
i rejet by using the next biggest tip cleaner that fits, replace, repeat if necessary
Re: Carb re-jetting
i rejet by taping more bottle rockets to my wheels. yee haw!!
http://www.mopedriders.org/article_view.php?faq=2&fldAuto=8
