Re: HELP ME! (if you're still up)
Frank Garland /
My guess is fuel flow....You got a piece of rusty junk caught up in your outlet filter inside your fuel tank that was blocking fuel flow. When the bike set for awhile, it settled back to the bottom of the tank. It will be back!! The outlet is at the bottom of the tank where all the crud settles. For that reason, I try to run with a full tank and avoid using fuel down to the reserve level.
