Re: Engine runs then dies
Ryland /
if you can go the same distance befor it stops, then you are running out of gas, it's running on what's in the float bowl and only getting a slow dribble, so you stop to start it, and while kicking over, it gets enough fuel to run again, I saw one carb on a Pennys Pony that had a fuel filter screen in a banjo bolt on the carb, tiny little thing, cloged like you wouldn't beleave.
