Tomos leaking trans fuild
I have a Tomos Sprint that is leaking transmission fluid around the inside of the bushing of the sproket shaft. I originally thought it was seeping out the the pedal starter shaft, but it is not. There is a 36mm seal on the outside of the transmission housing, but I think this only seals the shaft bearing behind it. Is there anouther seal I am not seeing or do I need to split the case to find it?
Thanks
