one last Motobecane question
Hello, my 1979 motobecane has casuse me a world of problems, all the way down to a slightly desquinishable burn on my forehead from its muffler. it has spark and compression. the only was to get it running is to pore a tiny bit of gas into the clylander spark plug hole. it continue to run but won't idle without a little throttle pressure. my carb is completely together. it is missing the choke cable... but never has been a problem before. i completley cleaned it and it will not run. i think it isn't getting gas. and help? thank you in advance , Mike Serfozo
