Re: What kind of grease?
Bort Hoff /
That is, use that stuff for the headset (steering column) and any bearings. Use some cheaper grease for the shocks, because you'll need a lot of it.
Oh and as for the freewheel (flywheel) you mentioned in another post, you should ask the bike shop you got it from if it's rebuildable.
As far as the shoddy finishing job, well, you guys did try find the rock-bottom cheapest place that would do it.
