Re: Puch Carburetor
joseph ho /
well the only part connected to it is the exhaust manifold and gas line. loosen the screw thats making the carb clamp onto the manifold
then twist it off (you might have to loosen the coil screws to make it easier. then you unscrew the top two screws on the top of the carb where the cable and choke is. you remove that you dont have to take apart the cable mechanism. pain to put back if you dont know what you're doing.
then you just pull the gas line off. make sure the petcock is off.
