points
I have 2 peugeot mopeds and I cant get the points set right. Does someone make an electronic ignition kit for it? If not how do I check when the points are opening. I have a meter but I dont know where I should put the leads at. Any help would be great.
Re: points
Re: points
No offense, but if you can't figure out how to adjust and time a set of points, what makes you think you are in a position to install and time an electronic ignition?
The Peugeot system is a little different than others, but you can still time it with a meter.
Re: points
I just need to know where to put my leads to check when points open.
