Re: Bi-Turbo question
Xxxxx Xxxxx /
It is a more efficient exhaust,and when combined with a larger jet,will make your moped go faster,and make more noise.The catch is,when it comes to engine modifications,nothing is free.Besides the cost of the exhaust,and the jets(I'd get at least 3,so you can dial it in right)your engines bottom end(crankshaft and rod bearings),clutches,and transmission will not last as long,because they were designed for stock power output.What puzzles me,is why you can't buy better parts.I'm a drag racer,and every single part of the engine,clutch,transmission,driveshaft,rear end,axles,etc.,on a car can be upgraded with higher quality aftermarket parts.Why is this not true for mopeds as well?
