WRIST PIN SIZE ?
What size wrist pin comes with the stock A3 ?
Re: WRIST PIN SIZE ?
sorry about the all caps
Most A3's had a 10mm Wrist pin but I belive some of the later A3N'S Had a 12mm.
Grey
Live to ride, Ride to work
Whats the difference between a A3 and A3n ?
The A3 has the 10mm and the A3N usually has the 12mm wrist pin.
I belive thats the only difference. Search the performance forum and you should find tons of info.
Grey
Grey -
That would also require a new piston and connecting rod, wouldn't it?
Yea obviously the piston would be different, I dont know if the conrod changed or if it had a different bushing at the end. I guess brock would know.
Grey
alright, some A3-N's do use the 10mm wrist pin and i found that out wheni opened up my cyclinder and my 45mm parma kit would fit. Right now i sanding down the bushing. I need like 1 more millimeter. You could buy puch bushing and it should fit..Yes i've been sanding for a couple of days!
I've got a 12mm pin on the way and a tomos a35 70cc complete speed form MARTIN RACING PERFORMANCE . I guess when it gets here I'll find out . If you guys know any tricks please let me know .
10mm
ya i think you will need a new bushing too
Read this thread http://www.mopedriders.com/viewtopic.php?t=286
Grey
Live to ride,Ride to work
So as long as i get the piston on i'm in good shape.
RIGHT
ull have to knock the old wrist pin out then put a 12 mm one in the it will all works out
