Re: Sand in the pedal flywheel... =(
Legendre /
Harold,
When you give someone a set of parts to sandblast, they are going to sandblast the parts.. it's not their job to mask off certain areas - their job is to clean the metal. Maybe they didn't know that the freewheel had a sensitive mechanism in it, nor is that their job.
Guess you learned the hard way this time. On the bright side, it will only cost you $20 or so, and it's one mistake you will not make again.
