Puch Running Lights
I just got a Puch 1977 Maxi, however the running lights do not seem to work.
when i press the brake lever, the brake light works. but i cant get the headlight or rearlight to function.
Which setting do i use, ive tried all three in order from low-light-low
which one would i use? and what bulb should i go about replacing
thanks
Re: Puch Running Lights
Matthew Libhart /
If the headlight is burnt out, the tail light will not light. Check the headlight bulb first. If it's a sealed beam, take it out and get one of those 6V lantern batteries at wal-mart and try connecting the light directly across those terminals. That'll tell you if it's good or not. That's the first place to look.
hey thanks, it was the headlight, i got it all fixed
Matthew Libhart /
Those Austrian engineers were brilliant and totally nuts at the same time. By making the tail light coil work off of induction from the headlight coil, they saved a whole wire in the construction of the moped. I guess thousands of wires add up, but really.....
