brake cables sticking
how do i stop my brake cables from sticking?
Re: brake cables sticking
Either oil them or replace them, if they still stick check the drums.
Grey
Live to ride, Ride to work
how do i oil them
along the brake line there should be a little bubble with a pop off cap. thats where you insert lube
follow the cable all the way from the handle bars to the brake and check and see if the wire is getting pinched by something. The brakes on my sprint stick all the time and it gets pinched under the carb so i just start from the top and work to the bottom.
get a hydrolic oiler... or make a funnel out of plastasine and put it round the top of the cable then fill it with oil and leave it upright overnight or until the oil drips through.......
shane
Jack, when I thought my throttle cable was sticking, it turned out to be the throttle grip itself... it seems like the rubber grip had begun to break down (maybe in reaction to WD-40 or something?) and had started turning into a gum inside.
Anyway, I know it's not the same thing, but I guess there's a chance your brake lever is at fault... maybe the pivot is over-tightened, or is getting rusty.
Lube the pivot arm in the brake drum.
