motobecane carb still leaks...
I am having a major fuel leak out of my carburetor. I have a 1976 motobecane 50. I have traced the leak to come directly out of the float bowl via a 'tunnel' that looks to be a drain. However, I don't want it to drain. Is there supposed to be a plug there?
SEE THE PHOTOGRAPH FOR ILLUSTRATION~ DAvid
Re: motobecane carb still leaks...
I have already checked my float direction (needle pointing up)
any help?
You're missing a part or two.. there should be a countersunk-style phillips head screw in that hole, with a little gasket (o-ring I think) behind it.
The screw is short, about 1/4" long overall. See if the hardware store has something with the right thread.
I see that youn have another motobecane,pull the bad carb out and size it up to the other one and see what's missing,like what's wrong with this picture.
nope. just one motobecane. a 76 50v
There is a screw that probably vibrated loose from you carb, i have a parts carb if you want it, but i'd rather sell the whole carb.
It's dirty, but complete except for airbox and filter.
If you can't find a screw that fits, let me know if you want mine carb.
or, ask dan adams if he has a spare screw.
